Dumb questions
pcoff61
10
ut
I have a Van w 6 - 6x8 speakers....I replaced the front with Alpine R 5.25 components... & replaced the rest with new 6x8s ...I replaced the head with a 7897... It's better, but still not great... I haven't added a sub yet, but will soon because the bass is making the rear speakers sound like mush ...I haven't tried to tweak the EQ yet because I'm wondering a couple things....do bass blockers work or are they a gimmicky fix?... is a 5 channel amp an OK option or could I keep the 7897 powering everything but the sub & get a simple amp for the sub? I listen to old stuff mainly like Steely Dan...etc..so I don't need killer bass just decent base with everything else just tightened up...I just want it to sound as good as I remember it did & as good as it does still on vinyl...any clues would be great...
Thanks, clueless Pete
Whats the different between a "Component System" and a "Speaker"
I think I decided on a Cadence TXA-6004
600 x 2 @ 4 Ohm, power my front Alpine Type-R (are these speakers, or components?) and a Alpine Type-R sub.
does that sound like an ok idea?
thanks for all the help. Im kinda in a stump now that I cant use the sub and coaxials on the same amp.
I have about 300$ to spend on an amp(s) and a subwoofer, and I think I decided on the Alpine Type-R, leaving me about 180$ to spend on amp(s), any ideas?
Also
SPECIFICATIONS
4 Ohm RMS Power: 4 x 150 Watts
2 Ohm RMS Power: 4 x 300 Watts
4 Ohm Bridged RMS Power: 2 x 600 Watts
Frequency Response: 20Hz - 30,000Hz
S/N Ratio: >100 db
Damping Factor: >200 @ 100Hz
Minimum THD:
Dimensions: 25" x 9.3" x 2.12"
FEATURES
High Speed Mosfet Power Supply
Studio Grade Bipolar Output Stage transistors
Fully Adjustable 18dB/Octave Crossover
Fully Adjustable Bass and Treble EQ Controls
Adjustable Input Gain 170mV-5V
2 Ohm Stereo Stable
4 Ohm Mono Bridgeable
3 Channel Mixed-Mono Capable
Power and Protection LED Indicators
Full IC Controlled Protection Circuitry
Mute and Soft Delay Circuitr
Lucite Encapsulated Terminals
Does that mean that its capable of running speakers and a subwoofer??
start a want to buy thread for a 2 channel and mono amp. say your looking to spend a total of about 180-200$ and you will get some hits, post up what your sub and speaker power ratings are and you will have people who have what you want. the best thing for you to do with your budget is buy used.
pcoff61
pcoff61
ut
blackbonnie
