Dsp settings
I have a general idea on the subs 80hz
the tweeters above 2500hz
but on the 6 1/2. And the 5 1/4. Should I be putting them on the same range
or should the 6 1/2 be set a little lower and The 5 1/4 set a little higher
how high would you go on the 5 1/4
no, the mid plays just up to the tweeters range
how mines tuned, more or less...
tweets play from around 3k up
my 6.5s play from 80 to 3k
sub plays from 80 down
this gear you all ready have? what gear is it? what vehicle?
3 ways are usually like a 6.5, a 3 inch and a 1 inch tweet
Gear already
focal iss. 165. 6. 1/2
focal iss. 130. 5 /14
focal iss tweeter
but could change out if need be
you can overlap or you can send different frequencies to each mid. id just play around with the settings and see what sounds best to you.
Jimg
CarAudio.com Regular
Jimg
nauc
