Dsp settings
  • 2
I have a general idea on the subs 80hz
the tweeters above 2500hz
but on the 6 1/2. And the 5 1/4. Should I be putting them on the same range
or should the 6 1/2 be set a little lower and The 5 1/4 set a little higher
how high would you go on the 5 1/4
Nauc
do you set the 5 1/4 to play 100k to full range 20,000k
or do you set a top frequency stop
no, the mid plays just up to the tweeters range
how mines tuned, more or less...
tweets play from around 3k up
my 6.5s play from 80 to 3k
sub plays from 80 down
So it is ok to overlap the 6 1/2 and the 5 1/4
set 61/2 80k. To 3000
set 5. 1/4. 100k to 3000k
this gear you all ready have? what gear is it? what vehicle?
3 ways are usually like a 6.5, a 3 inch and a 1 inch tweet
Gear already
focal iss. 165. 6. 1/2
focal iss. 130. 5 /14
focal iss tweeter
but could change out if need be
you can overlap or you can send different frequencies to each mid. id just play around with the settings and see what sounds best to you.
I have been fairly lucky that my hearing is still really pretty decent compared to most around me that I still usually tune by ear. Ive been doing...
15
474
355
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
387
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Jimg
CarAudio.com Regular
Jimg
nauc
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
