Dsp or not?
Hello,
Im getting system installed this week and next it consist of the following in a wrangler jeep
3 polk audio 12s
4 polk audio 6.5s
Polk audio 1200 mono amp
Polk audio 800 4 way amp
Ive had two installers tell me the amp crossovers and kenwood d992 head unit will work and no dsp needed but i want to be sure since the amps will be sunk into floor and covered in plexi glass.
If needed is the audiocontrol dqdx any good?
Sent from my iPhone using Tapatalk Pro
Seriously in a Wrangler a DSP is not going to do much good.
I would go with the installer recommendation.
Thanks man, i was just making sure because they ate building a leather false floor, sinking in the amps and covering with plexi glass so kinda hatd to change mind after thats done
Two posts though?? Cmon.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
710
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
563
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Arledge77
Arledge77
Phoenix, Az
Arledge77
    May 20, 2024
    May 20, 2024
