Dodge Ram 2500 Build 15" Treo SSX and Kenwood DD
  • 5
dye4metal
Tampa, Fl
Recently swapped out my Pioneer Avic-N3 (flipout), Kicker 750.1, Sundown SA8s in a sealed underseat box for some new hardware..
Truck is a 2004 Dodge 2500 Ram 4x4 Laramie Cummins Turbo Diesel. These trucks from 03-05 only allow a single din radio so i decided to change that. I dont have any actual build up photos but i have the finished product.
Headunit: Kenwood Excelon 8120
Sub: Treo SSX15
Amp: Soundstream 2500.1
Box: 4.0 Cu Ft (after Displacement) 6" Aero tuned to 29hz
video: the treo seems to be uncentered in the video? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
looks good. like the double din you did there. what other kind of upgrades you got in there?
As far as audio goes there was already a 7 speaker inifinity system that came with it and i just used a wiring harness bypass for the stock amplifier. They sound fine and get loud enough for my liking, which justifys spending days installing another amp and wiring the doors.
As far as the truck its got 7" Topgun customz lift, 37" nitto mudgrapplers, 22" cruiser alloy wheels, 5" straight exhaust, Smarty TNT tuning, tranny etc etc
no alt??? gotta keep the amperage up in the system somehow. 1000cca doesnt mean anything in CA //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif we all thought the same at first bruh
I responded with the CCA because i didnt know the grouping number nor the type... My voltage doesnt drop below 13.1 so the amperage is fine... //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
//content.invisioncic.com/y282845/emoticons/2thumbs.gif.fdc3ba010dbb42b61704534b46d02fe4.gif
Nice. Cool to see another local person.
Not sure if you have seen it or not, but if you want to check out a local forum, go check out http://www.floridaspl.com/forum. We list a ton of meets and events and stuff over there.
Im a member over there but I rarely get on...
just saw the USF meet was friday //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
4K
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
dye4metal
dye4metal
Tampa, Fl
dye4metal
