Dodge ram 2500 4x4 build log 2000
engine wise,
tps sensor
injection pump
lift pump
engine tune
air box
transmission build
exhaust
and a few other things that im sure im forgetting ..
Nice, thats a 24v motor right? I'm a Ford guy so I am not 100% up on the Dodge trucks but I know 98.5 was the change over from 12v to 24v but I can't remember when the CR motors started.
ya its a 24 valve ..
opening half rear doors ..
47 re trans along with dana axles ..
and a few other things ..
Its a fun truck..
Ill have more pictures later tonight ..
working on / finishing the box tonight ..
probably tomorow start wiring things up,
Then when subs and amps are in, put seats and carpet back in,
Then go for rear / front .. gotta at least get truck drivable again ..
okay guys ..
Sorry no pictures ..
all day event doing the box ..
ended up messing up the circle cuts and having to start over ..
Or woulda been done ..
so tomorow a lot should happen
wooh hoo for another Dodge Ram Rider check my build bud I'll be watchin
Well this makes three of us, check out my Ram also //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
amp rack is in truck,
aq 2200d
aq 2200d
zx650.4
zero gauge run to each amp,
zero gauge grounds
12 gauge speaker wire to front components
16 gauge speaker wire to rear coaxials
im thinking of making two seperate boxes for the subs, and then making a small seat between them ..
so far 60 sq feet of deadening on the floor,
have to do about that much for the doors .. and then install door speakers and tune everything up ..
truck is now fully wired, floor is darn near fully deadened with Edead ..
doors are waiting to get some plexi or if i cant find that MDF to seal what holes are in the panel ..
Then Raammat is going up on the doors,
most likely building two new sub boxes tomorow ..
along with center seat
then going down to let a shop do the final tune on the amps and get SPL tested,
I think they said they have an audio control or something like that,
Not quite a TL , but no place within 100 miles has one ..
the thumb nails are expandable to full size images .. and they are quite large ..
as far as updates ..
Both front doors are sound proofed,
Rear doors are gonna be finished tomorow,
along with coaxials and components put in .. then everything gets put together again ..
Everything basically is in ..
wires all done .. just gotta put trim panels back in and get some new door clips for the doors ..
well rear doors are ran with a set of phoenix gold coaxials off the zx650.4 , tuning by ear i barely had to touch the gains on the amp to have a very loud and clear set of rears ..
The truck already sounds better with just a set of rears added in ..
The door is sound deadened quite a bit ..
Doing the fronts with the PG components tomorow ..
and btw the 6.5 " speakers are almost straight drop in into the rear doors,
needed to grind about 1/8 inch off all the way around the mount and it fit right in perfectly ..
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif:furious:everytime I go to work on mine it rains:furious: and yesterday I went to do my headliner and my neighbor took my last can of spray adhessive:furious: so I said fvk it and got on here lOL
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
971
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Harleyfx69
audio n00b
Harleyfx69
arizona
Harleyfx69
audiobaun
    May 19, 2024
    May 19, 2024
