There is a lot of bassheads in Ohio and a lot in Michigan. A lot of shows around here too. Go to a show and get some demosI know, but I can't see or hear anyone's systems on here and I want to listen to other systems to get new ideas and compare mine.
2. No it won't. Less power requires less amperage. And higher efficiency.1; yes x2
the big three is a must-do for all installations, regardless of the current draw. this allows your current to have a larger path of least resistance to travel among the completed circuit in sustaining an even draw to and from all components either feeding or consuming current.
a 99 camry stock alternator is 90 amp max for the 2.2l and 3.0l v6. well below the amount necessary to supply current to the stock electrical components needed to keep the car running, power the acoutriments, AND supply a heavy draw of 700 amps (orion recommended spec) to just a mono amplifier while also taking into account the two rear batts constantly needing to stay afloat after deep dwells. the ohio gen alternator's regulator was most likely not set correctly (too high), or the current draw it saw allowed it to kick up into the 18v range, idk tbh, never dealt with ohio gen.
2; not likely. as already stated, that amplifier draws 700 amps. it will draw 700 amps at 2 ohm just as it will draw 700 amps at 1 ohm. halving the load resistance doubles the wattage, but amperage is a constant factor applied in this electrical formula.
3; always. the best analogy i can use, as i have for many years now,... is drinking a milkshake. do you prefer the big dumb straws from burger king, or do you prefer using a straw from a capri sun pouch or coffee stir?
there is no such thing as 'too much' when it comes to main power wiring in a dc circuit... not imo.
i believe what is happening when you have the big three connected, is you are allowing the batteries in back to charge just that much quicker (greater path of least resistance to the alt/front batt) after the amp has been relying on them to supply the bulk of the current during extended play at high volume, probably in the 12v range, which is why you havent smoked the amp yet. without the big three, it seems your batts in back are being taxed first and your power circuit supplying them is not allowing them to regain full capacity, thus slowly feeding off the front batt and alternator as a crutch with such a minimal ground.
huh?2. No it won't. Less power requires less amperage. And higher efficiency.
A 8k at 1ohm is not a 8k at 2ohm.huh?
ohms law doesnt change, bro.
14.4vdc x 700a x 1 ohm = 10080watts x .8 (typical class d 80% efficiency) ~8065w~ but we'll just go with a nice rounded 8k
rail volt-amperes needed;
square root of: power (watt) multiplied by resistance (ohm)
2000 x 4 = 8000
4000 x 2 = 8000
8000 x 1 = 8000
sq rt of 8000 = 89.4427va
this is the rail volt-amperes needed to sustain 8000w at 1 ohm driven cleanly, or 4k @ 2, 2k @4,.. etc, etc.
the rail va remains constant regardless of load resistance, thus, the current needed to supply said volt-amperes from the dc input will also remain constant unless dc input voltage or gain changes. more input voltage applied requires less current to attain rail voltage and just the inverse. lessening the gain will require less current as you are dropping the output power.
I think what he's saying is 8k at 1 ohm has the same resistance as 4K at 2 ohm. So 4K at 2 ohm the resistance is twice that of 8k at 1 ohm, but because it's half the wattage of the 8k the resistance is the same as the 8k so the draw on the electrical is going to be the same.A 8k at 1ohm is not a 8k at 2ohm.
JL Audio has their amps as so. Any impedance, same wattage. Which I don't like.A 8k at 1ohm is not a 8k at 2ohm.
Thanks man, this helps out a lot! I had no idea what the draw was. My idea was to play the stereo off the batteries. I thought I'd be good since I don't turn it up loud for long periods of time. I was going to use the voltmeter as a gauge to know when to shut the subs off(below 11.5), and let the batteries charge back up. The batteries combined have 210 amp hours and a total of 10,000 amps with an additional 90 AH from the alt for a total of 310 AH. Why wont this work for running a 5k system? (I've got an audiopipe 2k amp for mids and highs which is really 100watts x4)1; yes x2
Yes I've had a few. They are tightly regulated. But ******* current hogsJL Audio has their amps as so. Any impedance, same wattage. Which I don't like.
Lol what?I think what he's saying is 8k at 1 ohm has the same resistance as 4K at 2 ohm. So 4K at 2 ohm the resistance is twice that of 8k at 1 ohm, but because it's half the wattage of the 8k the resistance is the same as the 8k so the draw on the electrical is going to be the same.
But ohms = resistance, the higher the resistance, the harder its going to be for the amp to draw the power
Firstly, a rough estimate is 100a of current draw for every 1k in power. Obviously this doesn't factor in loss/heat etc.
It's MUCH more efficient for an amp to run at say 4ohm than it is at 1ohm because of resistance.
An 8k amp @ 1ohm is going to pull far more amperes than an 8k amp @ 4ohm. It is NOT the same, that is completely inaccurate.
Example:
higher ohm rating = less heatBut is that because 8k amp at 4 ohms is really a 2k amp //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
