do i need to use a crossover or not?
It will seperate the frequencies between the speakers. Otherwise you'd be sending the entire frequency spectrum of 80-20k hz to the tweet as well as the mid driver. That would not be good. That crossover is really small anyways, why don't you want to use it?
because i thought i can use the crossovers on the amp since i'm going to run the amp to my door speakers. I never worked with speakers that has crossovers. how does that work? and where can i place it since theres no room by my door. Can i just tuck it under my seat or something? And is that a set of speakers? I'm getting them for 55shipped.
from a person, it's used not new, i dont take business classes in college for nothing lol, its part of neg.
ok! but you dont know if they come in a set //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
The crossovers on the amp are just going to be a straight high or low pass filter - meaning they will stop anything belowe (variable) 50-250hz for the HPF, vice versa for th LPF.
A crossover does the same thing but its 2-way vs 1way on your amp. The midbas driver will be crossed at around 2000hz and the tweet will take about 2000hz up. You can get some velcro and stick it to the back of the crossover and the the other part to the inside of ur door, Thats what i've done. In fact, adhesive velcro is amazing handy in many situations with car audio I've noticed. Hope that helps
so i'm guessing using a crossover would benifit me? but if i dont use it will it damage my speaker and tweeters? what would happen to the sound quality? Is there like a wiring diagram that i can see how to hook up the speakers with the crossover connecting it to my amp?
Yes, use the crossovers.
wire from amp speaker outs -> crossovers
wire from crossovers tweeter outs -> tweeters
wire from crossovers mids outs -> mids
[edit] ^ beat me to it
You can run without the crossover, but you need to know how to tune it on your headunit or your amp for it to be able to work right, or without damaging the speakers as you stated.
More then likely use crossovers
Corollacrazy-Do you have a clue what you are talking about. Because I would really like to know how you can run them without crossovers, just by tuning your headunit and amp. Like you stated above.
Because either way you do it you will have to run either active or passive crossovers period.
You can run without passive crossoves if you heaunit or amp has the ability to handle that duty. Basically going active x-over vs. passive.
Just use the passives like poeple have already said.
nightrider45
nightrider45
Staten Island, NY
nightrider45
