do I need bigger amp?
Well the way you have them wired is all screwy with three and the way you wire them correctly with three reguires a 1 ohm load stable amp.......
imp rise will keep the amp above a 2 ohm load. That amp is just fine to push those three subs. I would suggest setting the gains correctly if not done already.
Plus I would also guess that the subs dont read exactly 4 ohms, they probably sit higher...I could be wrong though.
whojohnjones
whojohnjones
mississippi
helotaxi
