do I need bigger amp?
You may not have the voltage to keep the amp pumping full tilt at 1ohm, it's going into protect briefly. My rsd does the same thing when I go full tilt at 1 ohm. My amp is only rated for 2ohms though. What's your voltage drop?
imp rise will keep the amp above a 2 ohm load.
You can't make that assertion with any degree of certainty. Based on how his amp is behaving I would hold that to not be the case.
Plus I would also guess that the subs dont read exactly 4 ohms, they probably sit higher...I could be wrong though.
I've never seen a 4 ohm speaker that "read" higher than the nominal impedance. Doesn't work that way. Re, what you actually read on a DMM, is always lower than the nominal impedance.
whojohnjones
whojohnjones
mississippi
helotaxi
