DIY build for 4th gen Ram 1500 regular cab!!
Thank you to CARAUDIO.COM for all the help especially "SHREDDER2" for design, tuning, hints/tips, and headunit/amp setup.
I searched everywhere for 4th Gen Ram 1500 Regular cab sub boxes and only found 1/2" thick prefab boxes for shallow mount subs. i knew that if i wanted to fit quality subs in a quality box while not sacrificing any leg room, i would have to build my own box. i paired my zero box building knowledge with my year and a half old wood working skills and created an account at CARAUDIO.COM and the results were perfect! (with some bumps along the road)
if you have a 4th Gen regular cab Ram 1500 (mine is 2014) and you:
- dont want shallow sub sound
- dont mind losing the back carpeted wall, middle seat belt, and storage tray
- dont want to lose ANY LEG ROOM AT ALL!!!!!!
- want (2) Sundown Audio SA10D4s in a 3/4" MDF box tuned to 32hz
build this box!!!
Id get the factory panel from a salvage yard and cut that then cover with same stuff as box. If you ever go back to factory you still have your original.
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
DIY system turned out not that good....... 2014 Honda pilot (No metra Kit) so I have to keep factory HU I cut wires behind head unit and ran...
16
702
SAPHORZ
SAPHORZ
jacksonville florida
YukonXL04
