different voice coil configuration
mmm isnt it true that the sub with the lower ohm load will pull more watts than the other with the higher load...... example 1 ohm load> 4 ohm load......... the 1 ohm load will be moving more than the 4 ohm load ????
There are several different way to wire it and the final load will be different for each, and not one of the ways will give the same power to each sub. As far as which will get more power, that depends on how you wire them again. It won't sound right, and won't get nearly as loud as two of the same coil config.
The lower imp speaker will only get more power if you wire them in parallel. Wire them in series and the higher imp speaker gets more. If you were to wire the DVC 2's coils in series and wire the DVC 4's coils in parallel and parallel the two, the D4 will get twice as much power.
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
orioles26
orioles26
Severna park, Maryland
orioles26
