different voice coil configuration
mmm isnt it true that the sub with the lower ohm load will pull more watts than the other with the higher load...... example 1 ohm load> 4 ohm load......... the 1 ohm load will be moving more than the 4 ohm load ????
There are several different way to wire it and the final load will be different for each, and not one of the ways will give the same power to each sub. As far as which will get more power, that depends on how you wire them again. It won't sound right, and won't get nearly as loud as two of the same coil config.
orioles26
orioles26
Severna park, Maryland
orioles26
