Designing a crossover for a DIY speaker project
jaygeorge1979
alright guys i need some more help here...i have been browsing over alot of the DIY projects lately and i cant figure out how these ppl design the crossovers...i understnad how to build them ( i am an engineering student) but i cant figure out how they can choose a driver and know:
A. How to design the box, how big, seperate chambers, etc
B. How to design a crossover that fits the speaker perfectly
anybody wanna take a stab at teaching me?
You need to buy a book to get the general idea, the topic is too advanced to cover in
one post.
Pick a random midwoofer from PE with charts and maybe we can give you a
though process on how to tackle the crossover issue, simplified.
If you really want to expedite your learning, do this;
1. Buy a woofer.
2. Buy a midwoofer.
3. Buy a tweeter.
5. Buy a Behringer DCX2496.
6. Buy 1 amplifier channel, full range.
This will be a test bench rig so you can learn FAST on what goes on.
I can guarantee that you will understand if you follow my lead.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=296-145
i chose this audax midwoofer cuz it looked kool...it has all the charts on there, so if someone could enlighten me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
also, i have been looking at the passive crossover explanation on the12volt.com, and it has cleared a little of it up, but im still no understanding why to build them certain ways depending on which speaker you get...anyone?
thx thylantyr
You need to buy a book to get the general idea, the topic is too advanced to cover inone post.
1. Buy a woofer.
2. Buy a midwoofer.
3. Buy a tweeter.
how much am i looking at spending? what is a behringer DCX2496? wouldnt i also need to get crossover parts/etc? how about a box?
typically there are 3 engineering methods to use:
1.) get drivers that have a large overlap in bandwidth, then use a simple filter.
2.) use a complex, steep filter with speakers that have little overlap in bandwidth.
3.) use modeling software to find a middle ground for speakers with some overlap using moderatly complex filters.
from here, the crossover points are chosen based upon driver performance. drivers have well-known issues at both high frequencies (beaming, breakup) and low (overexcursion, T/S model). these issues help to define usable bandwidth. for instance, a speaker may have an excelent response up to 3khz, but then have a terrible response at 4khz. this means that even with a steep filter, the cutoff may need to be 2khz.
generally, filters should be below 300hz and above 3khz. 300-3khz is the most important band for voice recognition. this is only a loose rule though. i've used filters at 2khz with no issues.
DCX2496 is a digital crossover. $250 shipped.
Amplifier - you choose.
Drivers {individual speakers} - you choose
Get a cheap dome tweeter, cheap midrange to start the learning process.
Connect the DCX to your source and the speaker to your amplifier and play
with the digital crossover so you can understand what happens when you
change settings.
http://www.behringer.com/DCX2496/index.cfm?lang=ENG
For DIY, I only use 'active systems', one without passive crossover because it's
elite. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
For business, it's not practical to design an 'active loudspeaker' system, but
they do exist. It's more economical to do passive crossover design and just
hook up the speaker to an amp.
But, many DIY loudspeakers are passive crossover based too.
I prefer complete control over the drivers in loudspeaker design, hence all
active system so I can change settings.
You could develop on an active test bench to find the best settings then try
to make a passive crossover to mimick performance.
thx thylantyr
Everyone has their approach to loudspeaker design. My metho involves more
listening to drivers than measuring them .. because in the end, I plan to listen
to them not measure them -- //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I prefer a top-down approach to loudspeaker design. Start with tweeters and
work down.... because an excellent tweeter is harder to get than mids. After
you find 'your magic tweeter', find the matching midwoofer and so forth.
The frequency response for that midwoofer {midrange/woofer} you linked is
fine;
http://www.partsexpress.com/pdf/296-145g.pdf
Since my preference for audio is to use a tweeter that can perform well with
a 2khz crossover, maybe as low as 1.5khz using a steeper slope like 8th order,
we need a midwoofer than can play in this region well, with good SQ and
no nasty frequency response anomies like cone breakup modes in this region or
even higher.
The next question to ask. Does the midwoofer sensitivity mate well with your
tweeter? That midwoofer says 84dB sensitivity which is very low and inefficient.
Second, xmax is rated for 2.7mm so you need to understand that high excursion
isn't really possible with this midwoofer.
If you use a tweeter with higher sensitivity then make arranges by designing
an L-pad into the design to make sure you have a tweeter volume control to
attenuate the treble.
If you use an all active system, driver sensitivity matching is moot as you
will adjust levels on the source side.
What I like to do is make a list of driver candidates for a design and buy one
of each and hook them up to listen to them, this will be the final judging phase
on which one to choose. If you listen to enough tweeters and midranges,
you start visualizing in your mind on which ones mate better to certain drivers.
wow...that really helped alot
is there anything about a tweeter that would make me want to use an 8th order crossover at 1.5kHz for the tweeter, or are you just saying that is what you prefer? once you decide 8th order 1.5khz, is there a calculator out there that tells you what value capacitor to use?
how about for the midrange...if i want it to play freq between 300Hz and 3kHz, how do you figure out how to design that crossover?
i am still trying to figure out if there are any characteristics of certain speakers or brands that help you figure out WHERE you want to cross it over...i understand that once you know what tweeter you are using, you want the mid to overlap...but how to figure out if that frequency for the tweeter is efficient for THAT tweeter?
Here is something thylantyr said in one of his posts helping me design my line array... Main thing is the link.
Or would it be better to make my own? I can solder, I just don't know anything about making a crossover.
I think it would be better.
read this and tell me what you think.
http://www.caraudioforum.com/vbb3/showthread.php?t=227180
the passive crossover design will make or break that system so
you need to choose the tweeter, ideally find one with response graphs
to determine best crossover region to use then plan a strategy.
Linkwitz Riley slopes are just better for SQ, i'd use those, but
the LR 24dB/octave is more complicated to build and cost more
because it has more parts.
It has some good information and calculators on there, I found it helpful
-Ryan
wow...that IS beneficial...is the Linkwitz-Riley crossover the regular one that most ppl use?
i didnt know that all you needed to calculate crossovers was speaker impedance...thought it would be more complicated
i cant figure out how i would use taht calculator for a bandpass crossover for a midwoofer...say i wanted to filter out freq below 300 hz and above 2khz...how would i do that?
jaygeorge1979
jaygeorge1979
Corpus Christi
thylantyr
