Design help
You have the lengths and everything...but what are the angles on those angled parts?
And is that 6.5 true?...for some reason i think you have a bit more height than that, haha. Not to mention your sub not fitting //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif...i think its possible you meant 16.5"?
ill have to get exact measurements tommorow, ill get some carboard and see what fits snug. i just got some baseline dimensions to give you guys an idea of what i was wanting. and yea it is 6.5'' but it arches, so i can fit the sub in the middle or a little off to the side. if i have to ill get an actual picture and put the dimensions on with it.
Be sure you get a measurement of the height for the middle part.
lol yeah, i forgot about that in the beginning. like i said, ill get a cardboard template so that way everythings good measurement wise.
and pioneer~saturn, ill PM you tommorow with the measurements and everything.
thanks!
well, after thinking about it and going over all the stuff im gonna need to make this design sound the best in my car, i dont have the money right now.
im just gonna go with a more simple design and just go with the aeros.
will sub up ports back be louder than sub back port back? or should i just wait and do the ''mini wall'' design?
ok, tommorow im taking everything out so i can measure everything thats needed, ive been busy doing things around the house and whatnot, and i found out from a member on roe that you can fit a deep box in a cavalier trunk only if its about 13'' high or so.
so im gonna go that route and try to get measurements whipped up. i wanna use aeroports and bracing, as well as a double baffle if needed.
is the port calculator from PSP accurate? im sure it is, but just wondering. also would 6'' or 4'' ports be good for my BL?
bump, just got measurements, i have about 32'' wide, no more than 13 1/4'' high, and about 18''-20'' deep. anyone thats got a design or can help pm me.
thanks!
give me a top view, side view, and a view looking at the back of it (from behind the car with the trunk open) and I can render you a 3D image and get you the dimentions, volume, etc.
i have dimensions, its just i cant convert them to cubic feet. and i also need someone to chime in on what size aero's would work with what im planning.
boomzilla
Got 'Roids?
boomzilla
Florida
boomzilla
