Dd-1 and DSP
So set the gains with the dd-1 first.then use the DSP ?
Sent from my SM-N950U using Tapatalk
Yes and No, Hook up the DSP then set the gains, then use the DSP software. Most DSP's will have a higher output voltage then a HU, so it needs to be installed at the time of setting gains.
Right
So . No real answer? I have a 810 with output control so should I turn up the out put on the 810 till the distortion light comes on the set the gains on the amp ?
That's a nice DSP. That doesn't sound like a bad plan. But gains are not super hard to set. You can get 90-95% with just your ears.
Turn your amps gains down all the way. Turn your DSP gains down all the way. Turn your headunit up to about 75% volume. Start turning your DSP gains up, then your amp. Adjust to your hear either background noise,(hiss) or a noticeable change. Don't go obviously over and you will be good.
Double check your amp grounds and DSP grounds.
Ok, since you have a DSP with adjustable output, instead of a 2 part process, you would have a 3 part process. Turn up HU to max undistorted. Turn up DSP to Max undistorted, turn up the amp to max undistorted in that order.
That's what I did , I'll play with it for awhile and see how I like it .
tapcola
tapcola
US
tapcola
