cutting plexi
I don't think you want to cut plexi on a table saw.. But, yeah, if you end up doing that you can't use a normal blade.. you will shatter the plexi (or at least I think)..
Your best bet is to scar the plexi with a scarring tool and break it that way (at least that's the way I think you do it, haven't done it in a LOOOOONG while)..
Originally posted by Wkerat Do I need a special blade for my table saw to cut plexiglas?
I've never changed my blade in my table saw...I either use a rip blade or a finishing blade...
It really smells though...I personally hate the smell...its gross...
- Steve
My grandpa sells plexiglass. and i have cut it with a bandsaw... it cuts really easy... the problem is it gets hot and where you have already been it kinda melts back together. do you know how to bend it?
I have no idea how to bend it. I am going to use it on one side of a sub enclosure. I just have no idea how I will cut it so if anyoen knows a way better than the table saw please let me know...
Originally posted by ss3079 I've never changed my blade in my table saw...I either use a rip blade or a finishing blade...
- Steve
Is it hard to cut with a table saw?
i have cut plexi glass with a table saw and it worked very well...cut it like butter.... but if you are doing straight lines you put a metal ruler on the glass where you want the cut and run a sharp rasor blade along it a couple of times and then break it....that works.
Originally posted by ricerdude i have cut plexi glass with a table saw and it worked very well...cut it like butter.... but if you are doing straight lines you put a metal ruler on the glass where you want the cut and run a sharp rasor blade along it a couple of times and then break it....that works.
Will that work for 3/4 in plexi?
its scoring...not scaring ! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif anyways you could score and break that, but it would be hard.....table saw will work fine, they make acrilic blades for circular saws that they sell at home depot, i have a radial arm saw that i was able to mount the 7.25" cirular saw blade on....if you cant mount it on the table saw, put it in a circular and set a jig....the blades work really well.
If anyone is interested in bending it its very simple, i havent used anything bigger than 1/4" though. WE have some bare wires under a peice of leather type stuff(not really leather) and it bends it realy fast with some coaxing.
That works up to 5mm or so...
Now, tell me how you'd snap off 3/4" plexi?
I tried using dremmel, jigsaw, etc... all of'em messes it up... what I did was cut it with a jig, then sand the plexi slowly with a fine sandpaper... Oh, and when cutting, make sure you use lubricating grease specifically for jig cutting...that'd help a tad...
Bending Plexi... if it's a small cylindrical plexi, shouldn't have much problems with a tub of hot water... but with thick plexi, never tried... I remember seeing somewhere that they had to make special vaccumn contraptions just to get the bends in the plexi...
update me should you find out how~//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by paikiah what I did was cut it with a jig, then sand the plexi slowly with a fine sandpaper...
If you have lots of blades marks from the blade of the jigsaw/bandsaw, next time try a fine file to remove them first, then take the sandpaper(180-220 grit) and it will polish things right up.
It cuts like nothing.
- Steve
For me.. a compact amp that wouldnt take up a whole lot of room and not real expensive for a 350-600 rms sub@2ohms or even 1 ohm load id look at...
19
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
11
876
gain set well below "Normal" and base boost is off completely
15
Yeah, it's what I thought it was, but I wanted to make sure it was actually that. I'll get to fixing it when I have the time soon. Thank you guys
Wkerat
Wkerat
Scranton, PA
ss3079
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
