Crossover levels
as far as subs, id say like 80 Hz, for your components, it kinda depends what size they are, what brand they are, and what u wanna get outta them, it could be any where from 100-300 hz
Your question has no answer. There is no "better", "best" or "ideal". It is completely dependent upon what specific equipment you are using, how your stereo is setup, your particular vehicle, etc. There is no one answer. Someone could be using the same identical speakers and subwoofers as you, but end up using different crossover points for their particular installation.
Set them to where ever sounds best in your vehicle, with your install, to your ears. That is the only answer.
General ranges; Subwoofers should *generally* be lowpassed in the 50hz to 85hz region, component sets *generally* highpassed in the 50hz to 100hz region. But there are, as always, good exceptions to those ranges. And your particular install may fall anywhere within those ranges...or even outside of them. But it should give you an area to start with.
I am running one 8" kicker sub. It fits in the security console of my jeep, and it is a freeair model. The console isnt the best enclosure, but its what Ive got. As far as the components, Ive got Polk db 6.5 components.
icky4
icky4
Flagstaff
squeak9798
Mike Mccabe
