Dual 16Kv.2 IB FTW...Plenty of pics
~Magick_Man~
Well i finally got in my second 16Kv.2 so i got my baffle finished and subs installed.
at a later date i will pull it out and paint/carpet the board
Banged up package
Reason for delay
Extent of the damage
Luckily the sub wasnt hurt
Side shot
Yay for TWINS....
Another side shot.
Set on baffle for positioning.
Test fit baffle in car.
Trunk shot.
more pics in next post.
Sub sexiness.
Front shot.
And again.
Yet again.
Amp back in.
had to mount the amp "backwards" so i dont have to re-do the power and ground leads.
any comments would be appreciated, positive or otherwise.
thanks,
~Magick_Man~
cool, can't wait to hear it....it DOES look like one sub has a bent basket...it might be might drunk left eye though!
i think it must be you being drunk //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/toast.gif.bc0657bf54b9ee653b6438524461341e.gif
hows the sound? bet it gets LOW
Nice simple IB setup.
How's it sound?
well unfortunately i wasnt able to let it rip because i just got finished at about 11:00.
and i hope it gets LOw because that is why i added the second one.
the single one had enough output for me but the LOWs (20 hz) just werent there like i wanted them.
hopefully they will be now //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
~Magick_Man~
And your point is??
Neighbors are overrated anyways.
And your point is??
im more worried about the parents room that is about 20 feet from where i park my car //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i may just go drive around here in a little while just so i can hear it. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
sometime next week that directed amp will be replaced with a pair of viper 5 channel amps //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
~Magick_Man~
you are going to want about 500w PER sub in that setup. and make sure that baffle is solid as hell. looks like its gonna flex alot.
i wish youd of found a new way to get your wire through there though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
the stock wire harness has to get to the tail lights somehow. also sucks your plastic trim panels are all cracked up. try lookin in a junkyard for new ones? or possibly taking the broken ones off and carpeting the metal?
well when i had the single one running with 250 watts i could make it tap on the back plate so i think i should be ok with the power i will get from my new amps (300 ish per sub)
and the baffle is 1.5" thick and mounted pretty solidly so i should be okay.
in my last setup when the sub was wanging the sub would move about 1/4" or more //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif but i should be okay this time.
i am going to steal one of the ideas you had and make a frame/board covered in grill cloth that will hide everything so i am not worried about it that much.
yeah that sucks, they were like that when i got the car though.
i cant remove them because they stick out beside the seat if that makes any sense.
i might cut them back alot and carpet it for better looks.
there is still quite a bit to be done install wise i just wanted to get it in.
~Magick_Man~
well my impressions so far have been rather unimpressive.
but that is with them recieving maybe 75 watts each.
i am trying to get ahold of either a pair or viper 5 channel amps or a PPI DCX 1000.4
if i get the ppi which i really want because it is a sexy amp with plenty of power.
i will have to go back to passive because i will need ch3-4 for my subs
but with 125 watts per side and 500 for the subs it should do the job very nicely.
if i cant get that one and end up going with the less sexy vipers
i will have 100x4@4 for frontstage and 100x4@2 for the subs (100 per coil/200 per sub)
i would rather have the PPI because it is a much nicer amp than the vipers i am looking at and looks a hell of alot better too //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
but this is all dependant on wether or not paypal decides to **** me for about 2 grand.
those *****s.......**** paypal
~Magick_Man~
~Magick_Man~
~Magick_Man~
bedford,Tx
bumpin_blazer
