Crossover for my o6 civc
I'm assuming your using the factory HU... Get a GOOD LOC and tap into the sub output from the amp...NOT AT THE HU(it uses differential balanced output)...IIRC, coupes are under the center console where the shifter is, sedan it is under the driver's seat....anyway, splice into the sub output from the amp and run the crossover from the amplifier you are using, bypass the factory one all together.
Passive crossovers called bass blockers could be added to the factory speakers to help them sound better at high volumes.
You want a turn on output from the LOC. David Navone LOCs have that feature. Or a MTX ReQ.
Disconnect the factory sub when you add the new subs.
Memphis2011
Memphis2011
Maryville,TN
keep_hope_alive
