Creating a **** effect for L7 box.
Good kuck with it, but personally I think it's going to crack... when you layer up bondo THAT think you're going to have problems.
Alot of kids when I was in high school used to do that... called it "fiberglassing".
haha.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
the memory card in my camera said F___ it and lost about 20-25 pics that I wanted to post.
anyway I made it to the painting stage.
this is the 1st coat before I started wet sanding with 400 grit sandpaper.
yea I was pissed but moved on
Started wetsanding with 440 grit sandpaper.
Second coat of paint after it dries
I want a super glossy look any sugestions?
I'll post more later. Its getting late
lookin good, but your definitely gonna have problems with all that bondo. You should have at least made the metal template a little bigger and left it in place.
Don't use spray paint. Dude....you could spend 2 weeks trying to get it to look half decent. Also every time you sand the paint you are just taking the material off. That is just a waste of money. The primer should have been sanded with 400 to make it smooth and then paint applied on top of that and then clear. Automotive paint is the way to go. It is thicker and stronger than spray paint. As for the cost, yeah it isn't all that cheap, but look at what you will end up spending on "crap" to get it to look half decent. You can probably go to carquest and get a quart of single stage black paint and do it that way. It is harder to spray and make look right than base coat/clear coat but if you are going to be doing alot of sanding and buffing anyway, get it. You will probably end up spending $40 for it. You don't have to clear over the top. Hell for that matter go to O'reilly or Autozone and get the duplicolor automotive paint. It is really cheap. If you lived around here I would paint it for you.
if it chipped after a test fit, not sure the structural integrity is all that great.
isn't all that great???
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif plus your way is a double negative //content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
orphe
orphe
Houston
kpozr2
