Creating a **** effect for L7 box.
yea ur gonna have to paint it with some auto paint to get a good finish...spray paint imo almost always looks like shit. i dont think the bondo will crack cause we use alot of bondo on plastic bumpers and what not which bend and it usually does ok.. i would of just used some fibergel to build it up first and make it quicker. I hope your not sanding that all by hand? I would of had to use a da with all that sanding
A few things:
1. Your Bondo is going to crack
2. Bondo is a filler, not a structure builder
3. You fill those pits with putty, not more bondo.
4. Your bondo is going to crack
5. You need to be sanding with a block, not your hand.
6. See five to remove the waves in the bondo.
7. You don't sand after every layer of paint..
8. Use shop-vac to remove plaster from carpet when it falls off your box.
...other than those few things, it looks great!! Keep up the good work! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A few things:
its finished and so far, so cracks:veryhapp:
only problem is the L7 on the right is making weird sounds(I think its blown) and I might need to take it out.
while it doesn't look bad, that seems like a shi!t load of work for very little result. but hey props on the effort.
orphe
orphe
Houston
kpozr2
michigan born
    May 14, 2026
michigan born
    May 14, 2026
