Creating a **** effect for L7 box.
you do realize that when you put the subs in there and screw it in you will have to drill threw the metal too right?
also if you wnat to remove the sub you will have loads of fun //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
**** thats a lot of work.
wouldn't have been that much work had he been not so sloppy on the laying down of it...
looks nice though, what color paint?
and it seems like a lot of people on here go straight from like 120ish to 400ish.
speaking from plenty of experience(mostly high gloss black paintjobs) 120 does make scratches that 400 can't always sand out. i'm not saying everytime, but it's a good idea of getting in the habit of running over the 120 with 220 real quick. just a scuff is usually good enough...
just a tip, and it's just my .02
it would have been exponentially easier to stretch some fleece, resin it, then use a little bit of bondo to smooth it
x2
and probably more solid too....
really thick layers of bondo that either aren't prepared correctly or given time to harden correctly usually don't work out too well.
too much hardener and the bondo could crack easily(especially in a constantly vibrating application) and if you don't let the bondo set for a good ammount of time it could still shrink the next day, then it will just look nasty
bondo is waay cheaper than resin
$15*2 for 2 cans of bondo, about $12 in sandpaper
vs.
$30 fiberglass resin+ $15 bondo + fiberglass+ brushes and so on and so on and so on
orphe
orphe
Houston
kpozr2
