Could someone design me a box?
walterdixon
Hey, I have a Koda 10 that needs a home.
Box will be ported, ~1.5 cubes tuned to ~33HZ. (can be a little bigger smaller if need be).
Space isn't much of an issue, although, I'd like to keep the hieght down as low at 11" if possible, and not too deep (making up for it with width).
I would like it to be slot ported as well.
I am willing to send the designer a bit of $$ via paypal...
Thanks in advance.
I can do it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif using 3/4" MDF it cant be any shorter than 10.75 inches though because the cutout is 9.25"
i have built many ported boxes for subs **** as jl w6v2's ans w3's , all with a 1" port. No problems. Id say a w6 would out run a koda. also, the other problem is that if u wanted the port in wider, the port would need to be double the length, which is really long
if 2" is absolutly necisary, make the first part of the port wall 8.5", move it to the left an inch, then add 22"s to the 6.25" it will only be around 30 hrz then, but still, it will work.
ummm...you're going to totally have to re-design it...
You have to:
State a desire net volume
Add port displacement to desired net volume
Add driver displacement
State the desire dimensions of two sides, then solve for the needed length of the third side using gross volume (net+port+sub disp)
NG
walterdixon
walterdixon
Ontario, Canada
ngsm13
