converting a sealed box to ported?
  • 6
reasonable
I have an Infinity Kappa 104.7w in a 1 cubic foot sealed box that Im using for my 5.1 hometheater system. The HTIB came with a crappy 6inch ported sub.
I used to have the infinity in my car, but I replaced it with two IDQs.
Is there a way though to convert the box to ported? Maybe an aero port or two?
okay, it probably wont work.
According to the the spec sheet for the woofer. It needs 1.5ft^3 with a 9.2 inch port with a diameter of 3 inches.
Would the specs be any different for an indoor subwoofer?
Maybe I could just build a box? Much less headache?
Should I design the box according to infinitys design specifications for a vented box?
Or should I change it up since it will be for indoor use only?
I recommend modeling it in WinISD or Bass Box Pro for a high fidelity setup because response in a home is a WAY different from response in the mobile environment. Generally, for home use you are going to want to go with a larger enclosure that is tuned lower, like in the 20 to 25 Hz range.
Does bassbox pro output a 3d model of what it may look like?
I was playing with that earlier. It came out all weird though. It said the port wouldnt fit in the box.
I may ask you a few more questions lol.
lol, it will give you predicted plot... As for the port not fitting.... I call BS because you have plenty of room to run an external port inside of a house:laugh:
Key in the TS parameters and pick high fidelity ported or sealed for home use and see what BB Pro recommends. Sealed wouldn't be that bad as long as your F3 is a low enough frequency for you.
I'll give it another go. The first time it said the port would be around 900-1000mm in length //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
That does not sound right at all.
Ill give it another go.
use the formula in my sig and subtract 5"...cut you center tube to that length.
As for a coned speakers (woof, midbass, mid) driver polarity, a common household D cell battery works great. Connect the batter to wires, touch...
845
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
reasonable
reasonable
somewhere
Trixter
