Complicated Crossover Speaker Question lol
mega1268
Ok..... so im thinking about doing a 3 way set up on active crossovers.
I wanna run MY XXX mids and CSS 4.5 midranges of my kx800.4 should be more then enough to power both
I wanna run My vifa 1 inch silk tweets of a kx200.2
And my 13w7 is being ran off a kx1200.1
now my question is. Could any 1 give me an estimate of my crossover points.... should the speakers blend.. or should each be between a certain section. I know sub should play like 80hz and down tweets should play 4.5khz and up. And i heard the XXX mids play amazing from down low all the way up to about 1khz. it will play up to 5khz but ill lose resolution. So should the css mids only play between 1khz and 4.5 khz and the xxx only down to 80khz....... Any help would be very greatly appreicated.
Ok..... so im thinking about doing a 3 way set up on active crossovers.I wanna run MY XXX mids and CSS 4.5 midranges of my kx800.4 should be more then enough to power both
Looks about right to me -- I would play arround with xover points between 200-1khz for the XXX/CSS mid... 200hz would likely image better (depending on c2c) but on the other hand a higher point will make it a lot less likely to end up with a dead css mid... -- and between 3.5khz and 6khz with the CSS/tweeter -- to taste rly... again lower point should image better but higher will strain the tweeter less... I would also put a larger value cap in line with the tweeter -- say 40uF -- helps save tweeters... any sort of 0hz DC offset goes poof -- not to mention amp failure -- if there is an on/off transient by some fluke -- SEVERE amp clipping... ya know all that nasty stuff -- helps keep the tweeter alive
Yeah.....I would run the CSS as low as reasonably possible. Keep the XXX more of a dedicated midbass and in the midbass frequencies only, allowing most of the midrange to be covered solely by the CSS. Plus, as Trigger mentioned, you could get away with a lower highpass on the XXX.
Plus it's kinda hard to guess at this stuff as it's partially dependent upon your vehicle and installation locations.
can u give me a list of between what and what so i can sorta get an idea..... all 3 speakers are gonna be mounted in the door. as close to each other as possible. I heard this is thebest way. Its going in a 95 mustang GT with the doors sound deadened to hell. if that helps any.
i know im gonna have to tweak the freqs here and there but whats a basic setup to start. i know the xxx's play real low and the css i want to handel all midrange as it should.
Meh. If you don't have room for all of them down in the kicks, IMHO the "best way" would be midrange/tweet in the kicks and midbass in the door.
As far as the range. I'd try the XXX mid from ~50 or 60hz up to ~200 or 300hz, CSS ~200hz or 300hz up to ~6khz (if possible), then let the tweet take over from there.
But, again, that is just a general range to get started. From there it'll be mainly tweaking by ear and RTA if you have access to one. If not, then all by ear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Exact points will again be highly dependent on your install and what works best for your setup in your car. Underlap/overlap of crossover points may or maynot be needed. If you have variable slopes, the slope used will affect the crossover points. Etc etc.
can any1 recommend a crossover? it needs to be 4 way that can bandpass 2 channels? my HU has a 3 way electronic crossver. which has 18 db slopes and ccan bandpass a channel. but i would like to do it organized and all on 1 thing id otn wanna have to low pass off the Sub amp mid pass the css with the HU then midpass teh XXX mids...... ya know... is there any crossovers that bandpass 2 channels?
I'd suggest 60hz as a min -- you can do 50 if the Q of the filter is lower... -- 4th order or higher
6khz that CSS will start beaming a bit -- it is awesome even 60 degrees off axis upto about 2.5khz -- 3.5khz is still reasonable -- 4.5khz is more tweeter friendly... 6khz is very tweeter friendly but if you are too far axis there will be a dip near the xover frequency unless you are pretty close to on axis... -- besides an even power response creates a nice sound stage from even less than ideal locations -- that's my .02 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Already told him this -- just letting every1 else know //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He is putting the XXX touching the mid -- hes lookin at seas MCA15 -- exceptional cheaper 5.5" mid //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- so 400hz is doable on the xxx lowpass side //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif -- this is a place where just playing with it to personal taste is best...
is passive the best way to go.... or is there any active Crossover options i have that will bandpass 2 channels. id ont really wanna have to low pass off the crossover then highpass off the amp or vise versa.
Well you could add another 2 amp channels -- a nice active xover -- and some eq... that would be better but harder to setup and more expensive...
there is nothing wrong with actively highpassing and passively low passing the same driver... everyone with a passive component set at all that highpasses them to 'block the bass' with the head unit or amp is doing this -- and it works nicely.
All tradeoffs -- money vs simplicity
I've had my P9 for a while now and I'm still tweaking it from time to time. Mostly with the slopes. Its hard since all music is different. I don't really have access to an RTA and I can't afford my own.
Ok if i get a crossover my HU i bought has 6 volt preouts. Does this even matter anymore cause i think they boost the Voltage anyway off the crossover? Can i get a indash screen now with 2 volt preouts and not be worried? im running 3 amps?
mega1268
mega1268
NY
squeak9798
