Combining PreFab Boxes.
  • 2
Heathen
CarAudio.com Recruit
37
Auckland
I've a number of old enclosures which were included with Subs that I've previously bought.
Those Subs were put into enclosures which I created using the RE Audio calculator. Now I'd like to make use of these empty enclosures. It's a roundabout way of doing things, but I want to try something new.
I have two Kicker CompS 12" that I want to use for this project.
Using the two boxes in the attached image, I'd like to join them base to base (with an appropriate gap - held apart by top/back/bottom plates), and create forward facing ports where they join.
Is there some formula/online calculator I could use to figure out what size gap I would need in-between the enclosures? Or how much of the base plate I need to remove? Etc etc
Further to my last post... I'm specifically wanting to know how to tune to a certain frequency.
Also, I do intend on having a divider in-between those base plates, so that I can keep both ports separate.
Those are not ported boxes and it's likely they are far too small to ever function well ported. That said if you have 2 identical subs and these boxes are identical volume you should be fine running both in the same vehicle.
Those are not ported boxes...
Thanks for the response.
The subs are identical, but with a difference of 0.1 Ohm between the coils. Either way I wanted them, and their port kept separate.
The volume of the boxes are in the upper range of what is recommended, by Kicker, for a ported box.
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
910
https://www.amazon.com/gp/product/B0016G4EXQ/?tag=caraudiocom-20 https://www.amazon.com/gp/product/B07BMT699G/?tag=caraudiocom-20 Im not a fan of...
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
740
Don't get me wrong I've built a few boxes myself and I love doing it and it would've been preferred. But I now live in a one bed room apartment...
42
8K
They have pre-cut wood if you pay extra at the hardware store. Just draw it out. But you'll have to pay extra. Then screw it in yourself...
Heathen
Heathen
Auckland
hispls
    Apr 26, 2024
    Apr 26, 2024
