CMX crossover ?
yes it does. (page 4) B position just makes it a little louder.
In the manual it says
The component system has the ability to correct the sensitivity of the tweeter to project a linear acoustic pattern. Change the cable jumper on the crossover and connect positive tweeter cable to the different tweeter output terminals to adjust the tweeter level.
So be reading that I assume that the tweeter attenuation does not work unless you change the jumper?
It basically says the exact same thing in the manual regardless of if its connected to the A or B jumper. It says the same thing for both.
Its just the crossover has three positive connections for the tweeter plus the jumper, And I want to know how they interact with each other.
Like I said, moving the jumper to the B position gives the tweeter a louder/higher sound.
and no it doesn't say the same exact thing regardless of if it's connected to A or B
it gives you a list and example of the level of sound you'll get at each position.
I say you re-read the manual again.
Puggsley456
Who said you could talk?
Puggsley456
WPG>MB>CAN
nismos14
