Question about component watts...
This is just something I was wondering, not that I am planning on doing this, just wondering if there is a way to do it. Is there a way to determine the watts that the individual pieces can handle? For example, if a set is rated for 80w's, can the tweeter and woofer each handle 80w's or does the woofer handle say 50w and the tweeter handle 30w? Also, if I have a 80 x 4 amp and one set of components, can I send the power from each of the channels to a piece on the components, 2 channels to the tweets, 1 channel a piece and 2 channels to the woofers, 1 channel a piece? Sorry if this is a noob question, but I am a noob and trying to learn as much as possible. Thanks for any help!
1. Is there a way to determine the watts that the individual pieces can handle? For example, if a set is rated for 80w's, can the tweeter and woofer each handle 80w's or does the woofer handle say 50w and the tweeter handle 30w?
2. Also, if I have a 80 x 4 amp and one set of components, can I send the power from each of the channels to a piece on the components, 2 channels to the tweets, 1 channel a piece and 2 channels to the woofers, 1 channel a piece?
1. Usually if the set is rated for 80w rms, then both the mid and tweet are getting 80w rms. Unless there's a tweeter protection circuit in the passive crossover to limit the amount of power being sent to the tweeter.
2. Yep, but you have to have either a biampable passive crossover or switch to an active crossover.
1. Ok so unless there is a protection circuit, you can send 80w to each of the components.
2. What is a biampable passive crossover? A crossover that allows each of the components to be hooked up individually? What is a active crossover?
Sorry these are noob questions I know.
A bi-ampable crossover will have two inputs, one for the tweeter side, and one for the midbass side. Running active is supplying each tweeter and each mid with its own channel of amplificatoin and using an external crossover/processor to get the correct frequencies to each driver without destroying/distorting them. In this case you do not use the passive crossover that comes with most component sets.
OmegaBunny
Moderator
OmegaBunny
Keyser, West Virginia, United States
nismos14
