clamped creshendo bc 5500
what do u think it does .5 on 14v?
Hopefully rated. I wasnt to impressed with my old BC2K at .5.. Super inefficent and it sounded bad. I was told it blew from being mounted on the box not from voltage drop. I believe it cause when it blew the voltage was in the 12s.
wired to .4 rising to 1.01 ohms droping down to 13.0 volts drew in 720 amps of current dc put out 4890 watts. thats not bad for the voltage at all. i am honestly very impressed with the amp.//content.invisioncic.com/y282845/emoticons/happydance.gif.a963168fea27d8453c3ec467ddcf9e1c.gif
That makes it less than 50% efficient. If that is true, that amp is the biggest piece of junk on the planet.
ok i clamped a sundown saz 1500 v1 drawing 398 amps at 19 volts and doing 1600 watts....300 amps less than mine and 3200 watts less for all u sundown nutt huggers
no i am doing it right...clamped them with a 4 time world champion....were is your alls world titles? oh wait they dnt matter the 3000 posts do
Another .8v * that 720A (at 100% efficiency) would give you another 576w. I guess there's your rated. I suppose I'm just used to seeing big numbers from amps that are rising to 1 and not wired to 1. And for $900, I'd expect a little more.
Drawing 720A for 4,800w is retarded.
---------- Post added at 09:02 PM ---------- Previous post was at 09:01 PM ----------
Lmao. Is this serious?
joshy629
joshy629
lawrenceburg ky
Violence.
    May 24, 2024
    May 23, 2024
