kramer_212 10+ year member
really nice!!!!!!! only problem is that its drawling a ton of amperage for 5000w, whats the efficiency on this bad boy?
Hopefully rated. I wasnt to impressed with my old BC2K at .5.. Super inefficent and it sounded bad. I was told it blew from being mounted on the box not from voltage drop. I believe it cause when it blew the voltage was in the 12s.what do u think it does .5 on 14v?
So? Its pulling a boat load of amps to even do less than rated.its rated ay 13.8 though
That makes it less than 50% efficient. If that is true, that amp is the biggest piece of junk on the planet.wired to .4 rising to 1.01 ohms droping down to 13.0 volts drew in 720 amps of current dc put out 4890 watts. thats not bad for the voltage at all. i am honestly very impressed with the amp.//content.invisioncic.com/y282845/emoticons/happydance.gif.a963168fea27d8453c3ec467ddcf9e1c.gif
You are doing it wrong. Those numbers are all messed up.ok i clamped a sundown saz 1500 v1 drawing 398 amps at 19 volts and doing 1600 watts....300 amps less than mine and 3200 watts less for all u sundown nutt huggers
Lmao. Is this serious?ok i clamped a sundown saz 1500 v1 drawing 398 amps at 19 volts and doing 1600 watts....300 amps less than mine and 3200 watts less for all u sundown nutt huggers
