dailyrider123
Papermaker what brand welding wire is that, that you posted up? I'm liking that green 250ft for 250 bucks!!!found there site. looks pretty good. Is that considered THHN?
Oh never mind I was looking at the price for 1\0 , I supposed to get 2\0 welding to equal the size of 1\0 car audio wire right?
Ya I got some knu cca wire in my garage and it's wet and damp in there and it's fine looking ... Idk what's wrong with sky high but multi installs here in Michigan the wire is straight corroded, I've seen a few story's online of others having this problem too.i have ran cca for years and it looks and works fine
also i say a test years ago where someone replaced all his cca for ofc and gained .1db after the switch. iirc it was 4 positive 4 negative
I've never even had knu cca wire look this bad...
And people be like that only happens if the wire is exposed to moisture... Well duh what do you think happens in your trunk? Or in your truck. The weather changes all the time and it gets humid and damp and there's going to be moisture. Just buy good wire from the get go so you don't have that problem
Another company I've gone through isYa I got some knu cca wire in my garage and it's wet and damp in there and it's fine looking ... Idk what's wrong with sky high but multi installs here in Michigan the wire is straight corroded, I've seen a few story's online of others having this problem too.
I'm not sure about the car audio wire but the welding wire meets NEC standards. car audio is gennerally overpriced bullshit, welding wire that is used in the industry has ratings/code it must meet and it has to abide by NEC standards for circular mills to be labeled appporatlly.Correct
you know CCA is copper coated aluminum correct? i dont suggest aluminum wire and you better make **** sure that if you do you use the correct connectors for aluminum.I've never even had knu cca wire look this bad...
