Car Stereo On 2004 Honda Civic
  • 2
Brc1994
I installed a Dual single din stereo on my 2004 honda civic. Now for some reason the car keeps dying. Im assuming its because of the yellow (constant) wire. But the stereo turns off when I turn the car off. How should I fix this . Im a complete newbie
Well I've never heard of a head unit being able to bring an entire's car electrical down but I'd recommend replacing the head unit or going back to stock until you can get a different unit. As a newbie you lack the skills to properly diagnose the wiring, the one thing I will say though, I think its only a coincidence that the car dies as a result of the new head unit and something else is wrong with the car, but you wont know unless you put the stock unit back in and see if the issue continues.
You can go to theyre Website and check it out/do some research on your own, or even give them a call
33
6K
It should be called the accessory wire...it should be connected so that it only see power when the car is on...if its connected to constant power...
802
Unless Android made some big changes to their core program, it should work just fine. Just like using a 4g phone on 5g sevice.
If the original plugs have been cut off, you may want to get some from a wrecked car. You could also search online for a radio pin-out for said model.
Brc1994
Brc1994
minnesota
02WS6
