Can't find a 5in x 18in Port
Ramrod
Ozark, Mo
I need a 5in Port and I'm having a hard time even finding 5in PVC... I would like to have clear pipe, but will settle for anything as I can just paint it if need be. Would be even better if I can get the horned ends..
Thanks in advance
Psychoport's aren't happening for awhile I think. Could just make a slot port with .75" or 1" plexi
Looked them up, They are metal...Can that change the sound?
Its for a 4th order Bandpass with a blow through the rear deck...
No. I'm saying psychoport's aren't being made for like 6 months. No the metal is fine. I was talking about ordering 1" thick plexiglass sheets and making a slot port of you wanted clear.
I've got a ton of 6" PVC sitting in my garage. It wasn't cheap, but I could maybe sell some. Shipping would be the biggest cost.
Edit: Never mind, wouldn't be worth it for either of us.
Try Lowes, that's where I bought mine.
Thank you... Nice find... Not exactly 5in, but 4.75 and 5.75... Very close... hopefully they will work.
Quick question and last one about this link... Having the OD @ 5in and in the ID @ 4.75in... That would be a 1/16th wall thickness.. Is that going to work? Sounds thin......
Also found....
https://www.interstateplastics.com/Acrylic-Clear-Cast-Tube-ACRCLC.php?sku=ACRCLC&vid=201502022248-8p&thickness=5.000&dim2=1.250&dim3=1
Also found....
what did you end up getting?
I'm on the same boat now but i need 28" of 5" pipe
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
Ramrod
Ramrod
Ozark, Mo
C1500martin
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
