4th order design questions
raptor727
come get some!!
hello gentlemen it's been a long time since I've been on here but I've recently come across eight hdc3 15 and I plan on doing a fourth-order enclosure in my Chevrolet Tahoe. This will be my first fourth order so I have all the typical questions that come along with it I've built many standard enclosures and need to know what goes into the process of a fourth-order. How do you figure out tuning and airspace required for each sub? Does it differ when it comes to a 4th? Any advice is greatly appreciated.
You need to do a 6th order with those subs, suspension is way too stiff for a 4th. Unless they've been rebuilt with soft parts specifically for a 4th.
I ran 6 HDC4 18's in a 6th, worked out prett well. If you're considering a 6th PM me and I can give you some pointers on what I learned along the way...
My hdc3 18s did model better in a 6th order than a 4th on winisd. The 4th needed a huge port or else there was a lot of port noise A 4th order wall with 8 15s will require a lot of space and cant really go big with the sealed to port ratios to get that db gain. I would just do a normal ported.
raptor727
come get some!!
raptor727
pensacola FL
raptor727
