Can someone please make me box plans?
THXdts
Yes, it's usually not nice to ask for free, but what can I say. I don't know how to do box plans. If anyone has any spare time in there day, and feel like doing this, it would be awesome. I am looking for 1.5 cu ft net tuned to 34 Hz with 20 sq. in. of vent area. It is what Sound Splinter sugguests for the 12" RL-p. Thanks alot. If possible at all, I would like it to me more square..not like 29x13x13. That just seems akward as a box shape to me. Unless it takes away from the performance, then just do whatever.
here's a squarish box:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=19&Eh=19&Dia=6&Xmax=12&Vd=.1&NumW=1&Vb=1.5&Fb=34&Qts=&Vas=&Fs=&CE=0
look at all those port walls //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif and due to all those 180 degree turns the ports have to be wider, and therefore longer, making the gross box volume large (4.18 ft^3).
if you go with a less square design it'll be much easier:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=32&Eh=15&Dia=6&Xmax=12&Vd=.1&NumW=1&Vb=1.5&Fb=34&Qts=&Vas=&Fs=&CE=0
easier to make, port area more normal, shorter port, gross box volume
what vehicle is it going in? i'd just start with something as wide as the space you have, and a desirable height, and let the math figure out your depth. i don't really see any advantage in going with a cube.
That's cool but the only reason I don't like that one is that it gives me like 10 port walls. I only want like one..
You don't want a cube no matter what. I believe it's the second worst shape possible for a speaker enclosure unless you round off every single edge. Rectangular prisms are used for a reason; they have medium performance with the most simplicity.
it doesn't have to be that long and thin, you could do something more like this:
http://www.subwoofertools.com/forum/ported-box.asp?Ew=24&Eh=14&Dia=6&Xmax=12&Vd=.1&NumW=1&Vb=1.5&Fb=34&Qts=&Vas=&Fs=&CE=0
i wanted to know the max width and height you have in your vehicle and then i could come up with something that would fit nicely.
That one looks ****ing perfect. The only problem that I see is that you are using 12mm for the xmax and displacement at .1 cu ft //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif.
THXdts
THXdts
Maryland
xluben
