The signal that's clipped may have significantly more than 1000W of thermal energy...Why does
1000w-Sine Wave=Burnt Coil
1000w-Clipped wave=Burnt coil
I thought wire was wire? I though it could handle X amount of current.
Sine wave is at 0 dB, or full tilt for the amp. Clipped signal is where the signals tops/bottoms are cut off or CLIPPED, and causes the subs VC to play out of the gap in excessive heat burning the coils.
I **** at getting as technical as I need to. Sorry.
But current=currentAC voltage and DC voltage
How so?The signal that's clipped may have significantly more than 1000W of thermal energy...
Great thanks for all you guys opinions. This helps a lot though thanks.With a clipped signal, its like the top and bottom of the signal are "clipped" off, leaving them flat. When its flat, the coil stays still for a split second. For a sub to cool, it needs to have the coil moving to generate airflow to cool the coil. When theres no movement in the coil, heat builds up quick.
