Can someone help me calculate internal volume?
agarabaghi
Wood thickness 0.75
Width at all sections is 13"
All dimensions are outside dimensions
I need vol before displacement
The box is for a SA10, which im assuming is about 0.12 displacement?
I finall different recommendations for this sub:
Sundown Sa10
from sundownonly.com
Displacement 0.10 ft^3
Sealed box 0.5 cu. ft.
Ported box 0.75-1.0 cu. ft.
from ssa:
VENTED :
1.25 - 1.5 cubic feet tuned to 30 - 35 Hz
Yields F3 in the mid to high 20s
SEALED :
0.55 cubes for 0.707 Qtc alignment
Yields F3 of 50 Hz
why is this so hard lol...
im taking 2 boxes:
12.75 x 12 x 13
8.25 x 15 x 13
and putting each into 12v calc:
0.79
0.61
add them up
1.4
subtract .1 for displacement
1.3ft^3...?
Are u subtracting 3/4 inch .for wall of box on each side. 1.56 before displacement 1.4 after not that .1 of a cube is a big deal but I figured using cu in and converted to cu ft about as accurate as youll get.
pro-rabbit confirmed it was 1.39ft^3 before displacement, and going by the SA10 .10 displacement spec that would be 1.29ft^3...
Going to try a 3" x 15" aero port for a 30hz tuning will let you know how it sounds.
I would like to know said formula used by pro rabbit. The above mentioned is the only one I know for cu ft or maybe I hit a key wrong putting it in if he used same formula.
[(10.5*11.25*11.5)+(14.25*6.75*11.5)+(0.75*6.75*11.5)]/(12*12*12) = 1.46 ft^3 before displacement.
Far left rectangle, far right rectangle, airspace you subtracted from the wood thickness in between the two main rectangles that actually exists, divided all by 12^3 to change in^3 to ft^3.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
4K
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
agarabaghi
agarabaghi
Orlando, FL
DBBOOM
