Can someone help me calculate internal volume?
agarabaghi
Wood thickness 0.75
Width at all sections is 13"
All dimensions are outside dimensions
I need vol before displacement
The box is for a SA10, which im assuming is about 0.12 displacement?
I finall different recommendations for this sub:
Sundown Sa10
from sundownonly.com
Displacement 0.10 ft^3
Sealed box 0.5 cu. ft.
Ported box 0.75-1.0 cu. ft.
from ssa:
VENTED :
1.25 - 1.5 cubic feet tuned to 30 - 35 Hz
Yields F3 in the mid to high 20s
SEALED :
0.55 cubes for 0.707 Qtc alignment
Yields F3 of 50 Hz
why is this so hard lol...
im taking 2 boxes:
12.75 x 12 x 13
8.25 x 15 x 13
and putting each into 12v calc:
0.79
0.61
add them up
1.4
subtract .1 for displacement
1.3ft^3...?
Are u subtracting 3/4 inch .for wall of box on each side. 1.56 before displacement 1.4 after not that .1 of a cube is a big deal but I figured using cu in and converted to cu ft about as accurate as youll get.
pro-rabbit confirmed it was 1.39ft^3 before displacement, and going by the SA10 .10 displacement spec that would be 1.29ft^3...
Going to try a 3" x 15" aero port for a 30hz tuning will let you know how it sounds.
[(10.5*11.25*11.5)+(14.25*6.75*11.5)+(0.75*6.75*11.5)]/(12*12*12) = 1.46 ft^3 before displacement.
Far left rectangle, far right rectangle, airspace you subtracted from the wood thickness in between the two main rectangles that actually exists, divided all by 12^3 to change in^3 to ft^3.
agarabaghi
agarabaghi
Orlando, FL
DBBOOM
