can someone explain this to me??? term lab
you have four 10's in a box with like less than 30sq in of port or so right? i'll take dimensions of your box and your port information for $1,000 Alex!
27" long x 25" deep x 14.75" tall
one single 6" port. the pipe between the two flares is 4" long. i know i needed more port but i actually dont get any noise at all so i thought it would be okay?
Flip box around.
Im sure youll go up in score.....almost bet it ha
how much if you had to guess??? see im confused because i know people tune high for burps. i burped it and still did bad lol...
i will turn it in the morning and give it a listen... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Seal it up and give those subs some power, or rebuild that box with a slot, more port area, and tuned properly. Its only a 40 dollar mistake, pretty simple fix
well actually this is my third box. first one sounded awesome. it was a slot port tunned to 33hertz BUT i didnt like the design anymore. so i wanted a new box.
reason ive stayed with just one nine.1 is because i dont want the extra weight off a big battery. i have a 134ah C&D battery but my6 car almost crapped from the weight lol.
is there anyway to save the box? like just extend the pipe between the flares???
also why when i cut off the 2"'s did it sound 100 times better?
[/img]
[/img]
[/img] port firing thru skipass
[/img] my box in the car. dont mind messy install this was a quick test run
[/img]
pics for new comers
I never actually tested mine facing forward in my civic, but it was noticable too the ear too me.
Yeh....thats a bad phrase too go by "Tune high for SPL", you need too tune too ur cars res. freq.
Put a sealed box in there( one 12 or what not), and no other subs...play tones from 30-60 and see where ur car peaks at.....itll get you reallyyy close.
Than tune around that...not exactly too it, a lil lower.
My truck peaks at 43-45hz......i tune about 35hz....if i try too tune like 50hz, itll lose a good bit.
You could try too cut a new port face and go 3 4".
But the single 6in worked for my 4 10s, but i also had an assload of power too push through it haha.....id try too extend the port all the way too 6in from the rear wall.
Its not a bad box.....it shouldnt be the ultimate reason you only do a 138.
honstly all I want is a 142--143 off music.
I guess ill re do the port and make it like 17" total...?
where can I buy more pipe from? 6" pvc is too thick and no1 carry the sonotubes in 6" here...
michaellane
michaellane
tx
michaellane
