Can Someone Answer a Couple of my Questions?????
krj725
Im getting some subs. 2 12in comp kickers 150 rms 300w (pmpo) each.
What kind of amp could support this. Someone told me that i need a mono amp idk. Does it matter
GM-D8400M this is the model number of the amp i want
Could You Help.
specs on the amp and also what voice coil are the subs?
Tech Specs
Manufacturer Stillwater Designs
Output Power 150W (RMS) / 300W (PMPO)
Additional Information •Top Mount Depth: 5-3/4
Manufacturer Part Number 07C124
Standard Warranty 1 Year
Driver Type 12" Polymineral Cone Woofer
Manufacturer Website Address http://www.kicker.com
Frequency Response 27Hz to 500Hz
Brand Name Kicker
Impedance 4 Ohm
Product Series Comp
Product Name Kicker Comp C12 Woofer
Sensitivity 89.1dB
Product Type Woofer
Thats All I Got
You don't have to use a mono only amp. You can use a 2 channel amp and use it in a mono configuration or a 4 channel amp bridged to 2 channels (each powering a sub). You just have to be sure that the amp is stable at the load it will be given to drive.
That Pioneer will be fine so long as you can wire the subs to present a 4 ohm load. That means the subs need to be either single 8 ohm, single 2 ohm or dual 4 ohm coils.
well they are both 4ohm but i found a kenwood one that is 2 channel 1000w
250x2 rms
i really dont know what amp to get does it matter
well they are both 4ohm but i found a kenwood one that is 2 channel 1000w250x2 rms
If you want that style Pioneer the GM-D7400M or GM-5400T would be good choices. You don't have to max out the gains on the amp. There are a lot of inexpensive 300W amps. Look at Kicker, JBL, Infinity, Phoenix Gold (Ryval).
Probably shouldn't be hooking this up yourself. Main thing is if its not getting louder or sounds any worse as you turn it up, stop. You cant just max the gain out and let it play however loud it wants to.
im not one of my grandpas friend has been in this business for about 33 yrs he said he would do it for free
yea im getting the first pioneer one you said
I've got two kicker comp 12's running off a kicker zx 300.1 I'd get the zx if you can.. it works perfect for me. Although i do want to upgrade soon //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
thank you first person to actually tell me an amp to get. Would it be ok if i got pioneer because someone said its same quality just kickers more exspensive
if you have the money to spend go with the zx. mine barely gets warm and pushes the comp's perfect.
Do yours go hard like people hear you deff. I could get an 800w pioneer for the same price as the 300w zx right now both mono. I wanna go hard
krj725
krj725
Boston
krj725
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
