Can my car handle these two amps?
I've actually been wanting to do the big 3 but its getting alittle cold out here. I do have about 20 ft of 4 gauge wire in my garage. Does the big 3 have to be done with 0 gauge? Or would 4 gauge be ok? I want to stay my stock wire is 8 gauge.
Stock Camry electrical will dim lights when you use power windows. For your purposes upgrade big 3 with #4 would be fine and a good improvement in general. Make sure your primary battery is solid and you'll be fine.
^^This. If you don't plan on going bigger. If you see yourself adding more down the road, do it in 1/0AWG. If you don't think you will upgrade, then 4AWG will definitely be sufficient.
I dont think I'll really going to upgrade the sound system anymore in this car once I get the speakers amped. This my first car and I'm in college so the funds are limited right now. Next upgrade will probably be in a newer car will more high end audio. But I will keep in mind the 0/1 ga for when I want some serious power.
Someone start a thread poll and see how.many people have their big 3 done in 4 gauge
I use to but then I upgraded because I realized the amount of power I was losing!............just joking I did it because it looked better the only real benefit is reduce impedance, wire has resistance and the larger the wire the lower resistance but not by much it matters on long runs but in short ones there's not a big difference and anything is an upgrade to the stock wiring as far as the charging system goes.
Depending on op car most new cars come with 4g already stock. I personally would do the big 3 with ofc 0. Won't be too much more in price anyways
I do not see a problem with an addition of up to a 600 RMS Class D mono amplifier with 4 ga OFC wiring supply kit and be fine. It would be...
10
883
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
207
A Link would be very helpful. Id be interested in taking a look at some gear
215
654
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
Falloutkid90
Falloutkid90
Hartford, CT
audiobaun
