Can i replace these subs??
kotec123
Flame
hey, ive got a JVC HX-GD8 stereo system in my room.(yes is the most powerfull one they have made hehe)....and its got 2 7 7/8 inch subs (according to spec) in a "bass reflex" ported enclosure, with the port facing foreward.
My question is if i can replace these 7 7/8 inch woofers wt an "8" inch woofer, and if i can whats a sub that i can use? The amp that drives the subs puts out "195x2 min. RMS @ 6ohms at 63hz....to spec
so what are the best replacement subs? look up that model number at http://www.jvc.com if u need other info...
thanks
or basically what im askin is there any way to make this system better? anything at all.....maybe plugging the ports half way would make it hit lower? something anythign that improves it is appreciated
Home audio isn't quite as plug n play as car audio. You are going to have a hard time just slappin' another woofer in there and it sounding as good as the original speaker. You would have to know the original speaker's T/S parameters and Parts Express could probably get you pretty close. You might want to check into getting a replacement from JVC.
i realize that t/s will be a problem, but does anyone know enough that could point me to a sub that will be compatable wt a amp thats "195x2 min. RMS @ 6 ohms @ 63 hz? (according to spec) and that will match the enclosure in this system?
Dude you can still run your current speakers AND add a dedicated sub. The only thing the JVC will be doing is providing a signal to the subs plate amp. ie you would be jumping an additional + and - from one of your speaker connections to the subs high level signal input. It wouldn't be actually driving the sub.
kotec123
Flame
kotec123
Chicago
kotec123
michigan born
    May 14, 2026
michigan born
    May 14, 2026
