Can i make my sub run in 2ohm instead of 4ohm on a mono amp?
polm
EDIT*: Got the main problem solved. Is there a way to make my mono amp push my amp more? I don't feel like I'm getting 400rms power right now... It's running at 4ohm, Is there a way to make it run at 2ohm or even 1ohm?
Thanks!
Original post:
Hi guys,
I got a new setup and the sub doesn't work. Here are the parts I have:
Sony GT550UI head unit
Alpine sps 410 front speakers
RE65FR rear speakers
Sony XMZZR3301 amp
Pioneer TS-W309S4 sub
Sound ordnance 12in ported box
If you have anything to say about the quality of the stuff, please keep it for yourself...
So everything works except for the sub when its connected to the Head unit. If I plug my ipod in the input rca channel on the amp, the sub will work, even with the lowest possible settings on the amp (like practically no bass). But when I connect it to the HU, the sub doesn't work, at all. The amp has power, the green power LED is on and I've tested it with a voltage meter. The front and rear speakers work too. I've tried messing with the settings on the radio but it doesn't help.
Please help me solve this I'm kinda tired of this...
Thanks a lot in advance.
I've tried setting that. According to this crappy manual, I have to set Rb ENH to 1,2 or 3 but whenever I do that, only the front speakers work. When it's at off, all speakers power up but not the sub. Thanks for the reply btw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ok so I crancked the amp to the max and I get something. The bass is good but I feel it could be doing more. It's a monoblock amp so I can't bridge it but right now the sub is running at 4 ohm. Is there a way to make it run at 2ohm? Or even 1 ohm? Thanks
EDIT*: Got the main problem solved. Is there a way to make my mono amp push my amp more? I don't feel like I'm getting 400rms power right now... It's running at 4ohm, Is there a way to make it run at 2ohm or even 1ohm?Thanks!
If I understand your question correctly, no there is no way. 4ohm sub is a 4ohm sub. If you would like your amplifier to see 2ohm load, either add an identical subwoofer and wire it parallel with the current one or.. get a subwoofer that can be wired for 2ohm impedance. That's it.
I am not quite sure how you 'measure' your amplifier wattage by ear. You need an oscilloscope for that.
That's a likely way to clip your signal and destroy the subwoofer. I am almost sure you're boosting something that does not exist. That's right. If your recording does not have much bass information OR it's in the midbass region (should be played by fronts), the subwoofer will not be of much help here.
If you can't set gains by ear, at least use the DMM method.
http://www.caraudio.com/forums/amplifiers/531983-%5Bhow-%5D-setting-gains-dmm.html
just a little correction... you dont use an O-scope to measure wattage, you use it to see your sine wave... i.e. stop clipping... you'll use a clamp and DMM to measure wattage
Unplug one RCA and see if it gets louder. If so then the RCA cables are bad, one has opposite polarity.
I can't access the manual remotely as easy, do you have more than one preout pair?
You say not to comment on quality, but lower your expectations on how loud it can be. A better head unit would be easier to set up and probably give better sound. FYI for the future; I avoid budget Sony car audio, poor manuals are just one reason. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
polm
polm
Montreal, Canada
keep_hope_alive
