Can an LOC be used in reverse?
No, the LOC provides passive attenuation. This will attenuate in either direction.
For the record, not all LOCs are passive. Plenty are active. If it has a power wire, it is active.
Actually, I think the LOC that I use (which is active), PAC SOEM-T, will go either way.
What I'm trying to accomplish is adding an eq to a factory amplified stereo. I know it's easy when changing the amp for mids/highs, but I want to keep the interior speakers on the factory amp and just add the amp for my sub. The end result is that I want full eq control over the entire system which would consist of the factory amp for the mids/highs and my sub amp for my Q.
But I want to keep the oem look and retain all factory options with nav, satellite, onstar, steering wheel control, etc without having to buy a bunch of modules and interfaces to make it all work. I did all that with my last car and it was a pain.
I think the biggest issue you would have to over come would be the factory amps themselves. They have fixed eq/crossovers on them and even altering the signal coming into them you will still get a different signal after the factory amp.
Even if it's wired after the amp? I was thinking I could wire in a signal processor/eq after the amp with speaker level inputs in and put loc's in reverse on the output (with male to male adapters) to change the RCA back to speaker level to go to the interior speakers.
you cant have a eq after the amp unless you just add a filter to the + speaker wire.
and as rabbit said factory will have crossover setting and u tring to boost and cut you will end up with gaps in freq responce.
No, you can use EQ in the signal if you drop and boost the voltage. It will add to any EQ built into the factory. You can get EQs that have built in line drivers. It's just tough sometimes to know what EQ is built into the factory setup. You might have to measure it to know for sure.
Okay, let's do a little math here with voltages.
Say your stock head unit has voltages that would drive 4 ohm speakers to power levels of 15 watts RMS (and current capability / power supply to do so). P=V^2 / R, so 15 = V^2/4, so V^2 = 60, so V~=7.75v. Per the spec sheet of the DQL8, the max output voltage is 7.5v. So it can drive the output to about the same level as a head unit capable of 14-15WRMS @ 4 ohms. So yes, it is capable of this.
Just keep in mind that, as others have mentioned, your stock system may already have EQ in it. You can add your own EQ in with the DQL8 to cancel it out, but it can be hard to figure out what exactly to enter in order to do that. You may need a measurement system to do that. But if you just want to EQ in relation to what you already have, the DQL8 looks like one possible solution.
This would either be done on a Bose system or a ford audiophile system. I understand I would have to adjust on top ofthe factory eq but I'd be willing to tweak as much as needed. Am I correct in that I have to get active or powered loc's to accomplish this?
502
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
908
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
832
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
tooshort_128
tooshort_128
Sterling, VA
keep_hope_alive
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
