dragonrage
HU -> DQL8 -> Factory amp -> speakers should work fine with no additional LOCs or drivers. The DQL8 has high-level inputs and can drive up to 7.5v out. If the DQL8 is what you want to use, I would try it like that. If you need to add a pre-amp/line driver between the SQL8 and amp later, you can, but I don't think you'll need to.
If you don't actually want to use the DQL8 then let me know. Or if I am misunderstanding the chain then let me know.
The factory amp should not pull more than a few milliamps from whatever input it uses, so that shouldn't be an issue.
