Cab 1600.1 wiring help.
O
I have two DVC 2ohm subs to wire up, but when reading the amp manual it says Use 2x dual 4ohm (Do not use 2x dual 2ohm). Does this mean i bought the wrong subs? Sounds like it to me.
You can wire to 2 ohm mono (series parallel...1200 watts )... or 1/2 ohm mono (parallel)... that amp can do 1/2 ohm with decent electrical... but it's not recommended and won't last...
What subs?
it'll work 4 ohm each but u get less power, so yeah u really shoulda bought d4 subs
Ok so does it matter which positive and negstive output i use when i wire them in 2ohm parralel? The manual for this amp is only like 4 pages and alot of missing information.
2 ohm parallel... no, not with your subs... you need to series/parallel them to 2 ohm mono
Yea, i got my shallows in the fox box now my sa's will be here any minute, those shallows hit much harder in the new ported box. Cab 1600.1 is 1ohm stable so i shouldnt have a problem right?
The cab on the shallows... at 1 ohm... correct?... at 1 ohm you're good
Not the CAB on the dual 2 SA's at 1/2 ohm... it'll do it... but won't last long... at 2 ohm (series/paralleled) you will be fine but its not using all the amps power... can you get the dual 4 SA's?
it's 1 ohm stable but u will have to wire those d2's either 2 ohm (u get 1200rms total) or 1/2 ohm much more power but isn't great idea on that amp.. be great idea to see if u could try to send those subs back trade for d4's before u open them..
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
apeterson26
Memphis, tn
apeterson26
    May 24, 2024
    May 23, 2024
