Burping Questions.
Don't mess with your bass boost, or at least not enough to throw it into distortion at high volume.
Two common burp methods.
1. The full tilt. (meaning, you pause what tone you want to use then crank the volume to a level that you know isn't distorting. When your 30 second run starts, press pause so it plays the tone for 3-4 seconds then re-pause it.)
2. Slider (meaning, you have your pre-chosen tone playing when your 30 second run start then you quickly bring up the volume to the level at which it is loudest without distorting.)
I tend to use the slider method.
MONSONwarrior
Premium Member
Constantly Rebuilding...
MONSONwarrior
Baton Rouge, LA
snoopdan
