Burp box...
You build boxes faster than i do, thats for sure
Starting this was easy... I had all 4 main panels cut and sitting next to me... all I cut were sides and port with some 45's that were meant for the corners and ended up as panel bracing with the exception of the one in the port... I was working under the BEST of circumstances with some advice that gave me CLEAR direction... thanks man... it's a Craftsman Cordless Skilsaw job... LOL!
It IS getting a little tense around here lately... tell me if your wife would want THIS in the house... LOL!
The first test is it is LOUD... IDK where it is number wise but +3 db seems likely... I initially tried it with only 4 screws each sub with the hatch cracked open an inch and It was an improvement... then I put in the rest of the screws, sealed the hatch, rolled up the windows and opened it up...and it gave me a lil' ouch right in the eardrums!... We'll see tomorrow... thanks again...
The first test is it is LOUD... IDK where it is number wise but +3 db seems likely... I initally tried it with the hatch cracked open an inch and It was an improvement... then I sealed the hatch, rolled up the windows and opened it up...and it gave me a lil' ouch right in the eardrums!... We'll see tomorrow... thanks again...
If it's hurting like that it's distorting.
I'll take those type of comments in stride... they're expected coming from a SQ guy... LOL!.. it's cool... I'm happy and this box seems to have done it's job...
With that box you might be louder legal than outlaw. We'll see. Should be about 149 @51 legal
I don't have a clue what 2 CAB's strapped at 1 ohm on decent...(not great)...electrical will put out... 2 group 75's up front and 1 group 31 AGM in the rear with let's say a 200 amp alt (BNR claims 250A)... any ballpark guesses?... anyone?
I'm surprised that nobody has mentioned the AGM with no tray/holddown... that's another project for tomorrow... LOL!.. I'm still soaked with sweat from earlier...
Are you gonna clamp? Im guessing you should get 26 or 2700
I will if someone else has meters at the meet... I've only got Harbor Freight ones... and they are NOT accurate... I can attest to that as I just tested voltage and checked the impedance with only the leads... 1V off and 1 ohm off... it's not the leads as I tried another set... LOL!
Just stay above 40hz and you can still play stuff to test it out
Webbie 6 12s 45hz and 55hz
Jeezy Prime Minister 47hz
Ciara Goodies 51hz
Jay z Hello Brooklyn 2.0 49hz
Beamer benz or bentley 53hz
Project Pat Rinky Dink (rumble) 51-54hz
BTW... thanks for the selection, those all sound great... IDK what I expected but it actually does not sound bad at all... Rock is what I mainly listen to... at the meet I'll want something different... but I've got my SSF at 40 hz or so... just in case... //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
shredder1
shredder1
AZ
kr15
