Building my first box
Alright so today is the fiberglassing day... I got 2 rolls of extra wide painters tape... but my question is tinfoil, wax, WD40, or something else? What of that should I use so the fiberglass doesnt attach to whatever I lay down. I know jelly uses wax and I see alot with alluminum foil but WD40 seems like it would be the easiest if it actually works.
bmx and bass did yall plan out your avas here lol... anyways do you mean pam? Does pam work cuz Im liking the idea of a spray... but allumnium foil is probablly fairly easy as well..
Do I need to do more than one layer of allumnium foil I just put one down right now.
by my building experiance, less than 1 layer is fine. so 1 layer should be great //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Should I still be able to see the fibers or not see them at all. And if its kind of clunky... clunked together. Only on the corners though. Im only puttin stuff on the corners cuz I want to make sure its truly air tight. But is that ok?
So I just finished putting 6 layers of fiberglass on each side compartment bottom and 5 on the middle...
Then I realized I had 2 tubes of liquid hardner that came with my resin. Was I supposed to mix that in with the resin? If so I may shoot myself.
EDIT: Ok so I was supposed to... but is there anyway I can fix this or am I doomed?
BoondockSaints
BoondockSaints
DFW, TX
BoondockSaints
